Postby
rb20detsilvia »
https://forums.nicoclub.com/rb20detsilvia-u37186.htmlWed Mar 01, 2006 7:09 am
ok when im driving sometimes the car will just die and when i press the gas more it ussualy will kick back in and once in a while it will cut out when im accelerating any ideas
Postby
DrifterTom »
https://forums.nicoclub.com/driftertom-u32930.htmlWed Mar 01, 2006 9:54 am
a few things that i would check:1. if your bov is atmospheric you could be losing metered air and your mixture would be f-ed up.2. check good for a boost leak.3. check your tps for correct voltage and resistance.
i had this problem and thought it was the bov forever and come to find out it was my stupid tps
Postby
rb20detsilvia »
https://forums.nicoclub.com/rb20detsilvia-u37186.htmlWed Mar 01, 2006 1:00 pm
its a stock bov that i cruched so it gold pressure also it always wants to idle at a differant point and if you rev it up it comes down fast to about 2500 then slowly goes down the rest of the way
