Problem need advice
speedfreak358
Car: 1993 240 sx
ok so heres my problem, i have a greddy type s bov and i just got my motor running a few days ago. i had the stock 240 fuel pump so i didnt play with the boost its still at 7 psi. but i found out that the type s is for higher boost so its not opening if i'd hit boost and i get compressor surge. so iv not really been driving it and if i do i dont boost it cuz i dont wanna smoke my turbo. i need a hi flow fuel pump but my friend gave me one out of a 89 turbo supra, its a denso. the problem is i dont know how much the flow rate on it is and i dont want to turn the boost to 12psi if the pump can't handle it, running lean is bad haha. i have the part number its 195130-2590 also it says 0706p not sure what the number is for. i can't find it anywhere i'm just throwin it out there to see if someone by any luck has any clue.
THANKS!!!
the converted
Car: '99 BMW M3 6.0
'88 Toyota Celica All-Trac (somewhere in Cali)
'20 Toyota Tacoma
First with the bov, you can adjust that down in pressure levels so you shouldn't have any issues. As far as the fuel pump, you can get a walbro for under $100, so why mess with a 20 year old fuel pump.
Justin35ll
Car: s13 coupe sr20det
Yes get a walbroAnd that's why on the top of the bov it says "<--- soft/hard--->
