Mastaflash »
https://forums.nicoclub.com/mastaflash-u11595.html
Wed Sep 09, 2009 12:20 pm
i am trying to get afr to log with me aem eugo and datalogit, and i cant get it to work. i think i have a problem with my settings or i am taking the wrong steps.
i have the wideband signal wire going to the AN-1 position on the datalogit, and the box is grounded to a chasis ground from the 0V position on the datalogit box.
when i make a log it will trace the position on the map and leave only zeros ( 0 ) in the log as if it is reading a steady 0 volt signal. i checked the voltage directly at the wire and it was reading voltage varying with the afr changes.
if someone who has experiance with using the system can give me a step by step of what to do, and lmk if i need to change settings that would be very hepful.
thanks.
