Problem installing SAFC II
tvmendoza
Car: 240sx 95
Hello i installed my Safc yesterday and i followed the following diagram:zerothread?id=126070 (the pinout diagram)Which is totally different to the diagram you guys told me (N3-B) zerothread?id=134002
I ended using the pinout digram and then finding each cable needded. Is that going to be ok? or should i do follow another diagram???
Also i am going to be not turbo for another week should i follow the same instrutions that i am using:zerothread?id=95812
koukiKA240
Car: 1991 240sx KA-T
the International N3-b diagram is the proper once. I first started looking all of them up in my own pinout diagram i got with my fsm and the n3-b was showing it was for a rpm wire and the pinout traced it to like the lighter or something. But i went against the pinout and followed the n3-b and everything went smooth.~Sam
tvmendoza
Car: 240sx 95
My problem is that the n3-b has two lines and my computer has three which really make me confuse the pinout has 3 as well as mine but it is not exactly the same so what should i do/???
tvmendoza
Car: 240sx 95
Ok here is the deal, i have a 95 240sx i tried to use the N3-b diagram but it is totally different from my computer; This is the diagram that i found of my computer( on the service manual). And here is the n3-b
Is there any place where i can find another diagram or should it be the service manual diagram the one that i have to use( my mechanic told me that it is different, it has the same pins but where it should be a wire there is no one). What should i do?Maybe getting another mechanic or am i giving him a wrong diagram. Thanks
huguetpj
Car: 93 KAT Coupe
Just find the signal pins for your car on the FSM and connect the SAFC. Is not that big of a deal.
tvmendoza
Car: 240sx 95
I have to do it by myself, but i already wire it everything, once the pipes are done i will take some pictures and will show you the new KA-TThanks for your help
get_up_mark
Car: 98 240sx se
just remember that the diagrams facing with the wires sticking out and the pins on the other side. me and my freind wired my afc and it was all ****ed up and then we realized how dumb we were.
KFL
Car: S14
I installed the safc2 on a 98 a while back. Made this for reference, forget what diagram it was based off from though.
