Problem installing output shafts into j30 vlsd.......searched (lots)
will83
i'll try to keep this simple, i have a non abs 90 240, i purchased a j30 vlsd with abs. So I swapped the j30 internals into my 240sx non abs housing. After torquing down the endcaps I cannot get the output shafts to go in. The splines don't seem to be aligned, didn't know if there was a proper way to align them. Going to keep searching but wanted to see if anyone had any input.
sinkorswim91
Car: 91 240sx, 98 240sx RIP
u need output shafts from a vlsd you cant use your stock open diff shafts
will83
obviously you can't use the stock open diff shafts, they're about half the length of the j30 ones. I'm using the output shafts from the j30 diff. any helpful input appreciated
will83
will83
does anyone know how to rotate the splines inside the diff independently...
