SmithSR »
https://forums.nicoclub.com/smithsr-u5241.html
Tue Oct 09, 2007 4:12 am
You should be able to set the wheel smoothly onto the s14 hub. If you can't do that, check the usual spots for trouble. Assuming tire size isn't an issue, MAKE SURE that the hub bore on the wheel is clean and free from corrosion, and also check the hub on the car for rust and corrosion. Corrosion / rust is usually the problem with fitting oem wheels neatly.
Sounds like the wheel goes on, but not quite all the way...? Yeah, just clean up the hub and hub bore.
