How much boost are we talking about here? Most times when you're running too much boost and not enough fuel, it will snap, pop and crack your ring lands from detonation.drifting circles wrote:When I'm at wot I start to backfire it almost sounds like. I have a stock setup pretty much. fmic, hks bov 3in exhaust. I do have the stock fuel pump, could that be a problem?
whats wrong with 13psi? the odd number? im running 12psi on wastegate.float_6969 wrote:Yea, why are you running 13psi on the stock CA? What are you using to increase the boost?
What are you using to control the boost? If it's just the hose from turbo's vacuum nipple the wastegate and you're still seeing 13psi of boost, then your wastegate's actuator arm is possibly bent or you need to get some type of boost controller in there to regulate your boost pressures. What pump are you using? Fuel cut will scare the hell out of you. Makes you feel as if you've hit a brick wall or something. If there's leaks (which I doubt), you'll have this problem as well. Make sure your timing is at 15*BTDC as well.drifting circles wrote:Im not using anything. Its been like that since day 1...
Bro, W.O.T.+ No boost controller+ crappy fuel pump+ anything more than stock boost+ not knowing where your base timing is set at= A disaster waiting to happen. When I built that engine, I set the crank angle sensor in the proximity of where it is supposed to be; not spot-on. So please use the proper procedure to check and set your timing. I would hate to see you whack your engine because of simple little things.drifting circles wrote:no I dont. Ill look into getting one asap
IS that nescesary? im running a walbro for almost 2 years now without any problems, was one of the first things I built in. Hardly anyone on the dutch forums uses a FPR before stage 3, without problems.articzap wrote:Stock JDM timing is 10 deg BTDC.....
If you go Walbro you'll need an adjustable FPR, if you don't already have one.
only necessary if you are running rich. the Walbro tends to overrun the stock FPR.Anu wrote:
