problem at 180km
knight_240
Car: cars, martial arts
Hi to all,
I have a 93' 240sx SE coupe. The car will not go past 180km or 112mph! Do all 240sx are like that or is it governed? Does anybody know what the problem is or how to get rid of it. Its a 5-speed and it stops in 4th at 5800rpm's (redlines at 6900rpm). Please help, like to get rid of it if possible!
Thanks
slakker
Car: Cars and Comps
gove4rner
rousie13
Car: 2006 Nissan 350z Track Edition, 1997 Ford F250 4X4
There some wires you can cut in the ecu I believe or unhook some sensors on the transmissioin......things I wouldn't do to my car though. The way I'd go is getting a tuned ECU, which raises the rev limiter and gets rid of the speed limiter.
pmkls2
Car: 1990 240SX Fastback
I thought the rev limiter should only drop to 5800 rpm in 5th gear only, and that the top speed should be closer to 127 mph????? I've had my '90 model 115 mph speedo buried before it gets cut off...........
rousie13
They usually cut off anywhere from 112-117mph, not 127mph. But I could be wrong about that.
knight_240
thanks rousie13
rousie13
no problem....thats what we're all here for, to help others out
