Problem Aligning Timming Belt ?
jibroni69
I cant see the marks on the belt any more, so i am not sure how to align the marks on both the camshaft and the crankshaft at the same time? Can i just remark both the pully on the shaft and the belt on both ends and remove? Placing number 1 cylinder in tdc first then marking?
boost_boy
You don't need the marks on the timing belt, but you must make sure the cam sprockets and crank sprocket line up correctly.
undertaker
Car: C33
check the timing is ok by turning the motor over by hand before cranking it.
