Problem After TCM Install
A forum for the Nissan Armada, Infiniti QX56, and beginning in 2014, the Infiniti QX80
Reilly Family
Car: 2004 Nissan Armada
I replaced the TCU transmission valve body on my 2004 Nissan Armada. The shifting problem it was having is now corrected but now when it downshifts going through 30 and 10 mph, the engine does a light surge. The dealer said the TCM unit programming was set and cannot be erased or reprogrammed. Does anyone know how to fix this surging problem? I appreciate any insight you can offer.
VStar650CL
Technical Expert
2004 Nissan Altima 2.5 S
You could try having the ECM updated, the TCM may have a later firmware version than your original. It's normal for the idle RPM to hover and then drop when decelerating at low speed, practically everything Nissan does that. It's deliberate, the ECM backs off the last few degrees of throttle plate closure in order to prevent stalling or backfire on drop-throttle.
Return to “Armada Forum / QX56 Forum / QX80 Forum”
