Clawhammer »
https://forums.nicoclub.com/clawhammer-u53050.html
Fri Feb 06, 2009 5:02 pm
In that SR shirt thread I said my SR was really reliable.
Then the new year hits and BAM blown head gasket.
Fixed it and stripped the oil feed in the process.
Fixed that and drove it for the first time today in over a month...
Idling at 10 inHg, I think it normally idled at 20. Characteristic of a boost leak. Can't find anything. It's probably there but I can't find it.
In first gear, by 1500 RPMs it's pushing a couple pounds of boost already! wtf? Grandma it to 3000 shift to second and it's boosting instantly on the shift.
BOV not blowing off under low boost (didn't right before I blew the HG too...)
If I let if fall below 1500-1000rpms and don't downshift to the next appropriate gear (i.e. lazy rolling pause-stops at stopsigns in second gear) it bogs down real bad. Normally this would cause a natural bog as the engine gets back up to speed, maybe some shaking you know. Not this, this bog is a, I push the pedal to the floor and nothing is happening almost. Real bad. Same happens when coasting through a turn and not downshifting (say 3 to 2 or 4 to 3). Not good.
Stopping and pushing the clutch in at a stop sign causes RPMs to drop to around 400 for a second, then it goes back up to normal.
So I was not up to taking it across town to work today (just drove it around my neighborhood a lot).
Come home 9 hours later, won't start now. Just cranks. What the hell I didn't touch anything.
So, if you read all that, which I tried to split it up so that it's not giant walls of words...
Why is it running weird and why will it not start now? Pretty soon the answer will be: because I pushed it into the backyard and set it on fire...
