problem after problem after problem!!!!! but i still love my 240!
jepree
Car: 1995 Nissan 240sx
so can anyone tell me what the heck is going on with my ride? ka24de i start my car and it idles lower and lower and lower and dies! WHAT THE HECK! if i keep my foot on the gas for a while then it dosent stall but idles like crazy low! WHAT THE HECK!
has any one had this problem? i reset my e.c.u. but same thing! cant seem to figure out whats wrong? neither can my two mechanics! this is my last resort then its off to NISSAN and ill be broke forever!
HELP MUCH NEEDED!
Kenrik
Car: Nissan 240SX Coupe
Infiniti G35 Coupe
Nissan Versa Hatch
If we are you last resort you're screwed... lol j/k
I bet you it's one of two things (if you already did plugs, wires, cap/rotor, O2 sensor etc..) it's either your AIV valve (you will not have one if it's a DOHC) or your Idle intake control valve... clean both of those and you should be good to go!
90SXSE KA24ET DREAMS
Car: 1990 Nissan 240SX SE 5spd KA24E-T project
i am having the same problem but as it runs while keeping my foot on the gas the car back-fires..
Kenrik
Infiniti G35 Coupe
Nissan Versa Hatch
zerothread?id=125163 <--- info... I found it using THIS ----> <----
InsanityInc
If your idle drops lower and lower and it finally dies, your exhaust is probably restricted. Check your exhaust backpressure using a gauge designed for it. Probably just a screwed up catalyst or something.
jepree
thanks guys gonna give the ideas a go!
Ni2s4s0aSnX
Car: Nissan 240sx 2.4L 12Valve
If you tried all of the obvious reasons, cap, pugs, wires, 02 sensor, etc. I might have something to do with maf, or sensor wires.
Scooby24
Car: 01 BMW 330CI
I'm surprised no one has bothered to say timing chain, base timing, gooped up throttle body, etc.
Start with timing. Check that.
Kaikias
Car: 92 Nissan 240sx Ka24de
My fist guess was Idle Air Contol Valve, sounds almost what my truck was doing when I had to replace that. I would also check your fuel presure. Does it still do it after the car as warmed up or just when your first start it?
jepree
no mine stays idle and when i drive now the check engine light blinks on and off in no particular order. my o2 sensor loose?
Scooby24
Car: 01 BMW 330CI
That actually does sound a lot like an o2 problem....misreading and CEL is getting thrown and it's probably either running too rich or too lean and dying.
jepree
yea i got a new o2 sensor ordered in from nissan today and its like 130.00 canadian so thats like 100.00 usd! i tried everywhere here and no one else sells em! i love my s14 so ill keep her runnin good!
thanks again for all the help fellas, ill post what happens when i try the o2!
USDM240
Car: 1993 Nissan 240SX Limited Edition 'vert
your IACV is stuck. remove it and clean it and your problem should go away.
Kenrik
Infiniti G35 Coupe
Nissan Versa Hatch
USDM240 wrote:your IACV is stuck. remove it and clean it and your problem should go away.
I said that like Ten times!! It does not cost anything to clean it!!! you try the free fixes first!
jepree
yea true that hu! free fix! i wish all my problems were like that! thanks again!
