Problem 4001
WDRacing
I managed to ruin my MAF somehow. I was made a Hacked MAF out of the original, to what I would consider pretty damn carefully...but obviously to rough at some point. Now I can't rev over 2500. I reset the ecu, no avail. I started the car, disconnected the MAF...no change in idle or revving. So I'm 99% sure the MAF is roasted.
On the positive sode I got the car started with no oil or fuel leaks. I also have confirmed my new oil return system works like a champ. No more cutting the oil pan, no more running a restricter, no more having to run a quart low to keep from clogging the oil return line.
Plus my injectors definitly don't leak and the Mustang fuel rail works awsome.
If only I could drive it
fiznat
Car: Grown up :(
p i c s!
haha
D Money
Car: driving illegaly
lets hear more about your oiling system
toki
damn, you would think for a moderator of a KA-T forum you wouldn't be such a n00b, brian.
hahahaaaaaaaaaaaaaaaa
in other news, if you need a DOHC maf in tucson I can probably arrange that pretty quick here.
ILikeMy240sx
Car: SR Power
Yes, Im interested in learning about your oiling system... since I hear alot of people here put a quart less oil
toki
it's so crazy you won't even believe it when he tells you. so crazy, I even know what it is, but I wont tell you in fear of being called a crazy man.
Wrap this around your head: NO OIL RETURN TO THE OIL PAN.
thats just a teaser.
ILikeMy240sx
Car: SR Power
Did he tap it into the block? I kindda figured he wouldnt use the oil pan as the return
klattr1
Car: GT42R powered S14/KA
must be returned somewhere in the head or timing cover then (guess based on teaser).
gabossie
Car: Your mom
Do tell, do tell! I hate the idea of running a quart low.
eddiec
Car: 91 S13
dry sump?
WDRacing
You are correct my friend. More info soon to come on the oiling system. I want to make sure the parts I'm using hold up to some abuse before I give out any details, since I'll probably be marketing a kit for the S13 and S14 here pretty soon.
Course, I need to get my car running first. My neighbor is fessing up his MAF this morning. Gonna be hard using a stock MAF and 42lb injectors.
D Money
did you lower your motor since you dont need a big pan now? sounds awesome none the less though
WDRacing
You still need the oil pan, I'm not running a dry sump. Although I know a way I could now. Alot of work though...
Jookmasta
hey i think my maf got toasted too. describe ur driving/idle issues so that i can know for sure that it is my maf
Projex240
Car: Dogs , My RIDE
so whats with using the stock maf hacked? Wouldnt it be easier to use a z32 and some sort of tuning you may already have in place?
