Probing ECM Connector
TorQue45
Many diagnostic procedures in the FSM specify measuring the signals on the ECM connector. Has anyone able to measure any signal on the ECM connector?
It seems like all the CONSULT information can be retrieved through this connector.
DAEDALUS
Car: 1990 Infiniti Q45
Yeah, it sounds like it. I have measured all the pins listed in the FSM, but that was only with a voltmeter. If you have a data logger or scope, that would be awesome for recording traces. And you would need to know the voltage conversions for things like temp sensors, TPS, etc. Good idea.
TorQue45
DAEDALUS, thanks for the quick reply.
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
Ive done the same thing.. IF you could figure it out, it be golden...
SCOOTER240
Car: 1990 240sx sr20 black top
the only difference in using the consult and probing the wires at the ecm(do not pierce the wires!!) is the consult does all of the work for you-the information is the same as you would get with a dvom-just be careful when probing-it is possible to fry an ecm if you aren't careful
wamQ45
Working on it for the Q
