Maikeru wrote:
Also, currently I am putting power steering fluid into my car once every month or so. I shouldn't be having to fill it so often. Every month though the power steering fluid is 100% drained, I am puzzled to why it is doing this since I can't find a leak at all.
Thanks in advance for your help guys, it is appreciated.
well if your putting power steering fluid in yout power steering fluid resivoir I found your problem, you car uses automatic trans fluid in the steering ! yeah I know most poeple don't know this and that's why so many have leaks, PS fluid is mush thinner than ATF, I had to replace the rack on my Z#! casue the proir owner had made the same mistake, and the rebuilt racks are not cheap best deal I found was from Strano's in PA, and I 'd suggest you replace the tie rod ends while your at it, they are almost 20 years old now!and sounds like the Cylinderhead Temp sensor to me on your start problems, kinda a pain to get to it as I recall
