Probelmo Tried Everything i can Think of.
mparnelly
Car: 1992 Nissan 240sx Coupe
First off i drive an Automatic unfortunatly. Okay so my car runs pretty solidly when i can continously drive without stopping. As I slow down and eventually when i let the RPM's get below 1000 the car just straight up stalls.
Now the car won't stall in first gear but as soon as i accelerate enough for it to shift then slow down it stalls, basically when ever the car goes over around 3500 RPM the car will stall if i slow down. I cant figure out what it would be, i've checked hoses, vacuum lines seem to be just fine. Any Ideas?
Heres what i've checked
Fuel Pump - Brand NewFuel Filter - Brand NewVacuum's - Checked
Could it possibly be the timing? Should i adjust the distributer? Any help would be great guys thanks!
redsx13
Car: 93 240sx 03 350z
How does it idle?
honesty, it sounds like it has somthing to do with your trans...
4cefed
Car: 92 240SX Coupe
03 SRT-4
Various Dodge POSs
Search for threads related to the IACV. Sounds like it might be related to that. Mine, (manual,) used to do something similar so to band-aid it I cranked up the idle screw until is stopped stalling, which is wrong, but I could get to work and back.
redsx13
4cefed wrote:Search for threads related to the IACV. Sounds like it might be related to that. Mine, (manual,) used to do something similar so to band-aid it I cranked up the idle screw until is stopped stalling, which is wrong, but I could get to work and back.
yes, but that would have nothing to do with the fact that he said he will only stall if the trans shifts into a gear other than 1st
mparnelly
well it only happens when i slow down, the trans shifts perfectly, i really hope it aint the trans :P, I did fix it for a few days about a month ago when it was doin it, i put some fuel injection cleaner in and it worked for a few days, i'm wonderin if maybe its dirty injectors? or maybe clogged up wires?
4cefed
Car: 92 240SX Coupe
03 SRT-4
Various Dodge POSs
That's not what he said at all.
