probably a simple question
1980-1986 Datsun 720 forums. All 720-specific topics and discussion can be found here.
sawyer's720
Car: 1984 Datsun 720
does anyone know what all would be needed for the swap to fuel injected? i have an 84 z24 with a carb and im not passing emissions any time soon and its kinda scary to be driving around with expired tags. i would think all that would be needed would be the wiring harness, ecu, intake manifold and crank angle sensor. correct me if im wrong. also if anyone knows a link for a write up on this let me know. i've been searching for hours without much luck. thanks
cedar
Car: 1984 720 4wd KC
ran across this the other day. might help out:
How to Convert a Nissan 720 (1980- 86) truck to Z24i (fuel injection) from a D21 86.5 - 89 truck
http://nissannut.com/projects/z24i_fuel_injection/
EDIT:
also the last post on this thread has a little info. not much but a little:
http://forums.off-road.com/nissan-all/1 ... -sale.html
sawyer's720
alright thanks man. i hadn't seeen the second one. i was hoping that i wouldn't have to use as much stuff as he listed in the first link. he ended up using an original z24i so that kind of puts a damper on things.
Return to “Datsun 720”
