Ash108 »
https://forums.nicoclub.com/ash108-u89422.html
Thu Mar 06, 2014 10:23 pm
Hey peeps!
Just want to get to the bottom of an issue with my ecu thats happend for the 2nd time.
After fresh engine build,new wiring harness from COZ and Nistune via Emulation seems like my ecu has popped somewhere along the spark/ignition side of things- spark on 4 cylinders only-
Iv done the following:
Tested 2 working S2 PTUs
Tested my CAS- On 2 Cars
Tested coilpacks.
New Spark plugs
Checked Earth on motor.
Bridged Ignition Relay in Engine bay and only got 4 cylinders firing.
Took my ecu to a friend and tested it on his car,did exactly what its doing on mine,only firing on 4 pots,hooked his ecu back in and ran fine.
So just want pointers on probable causes of how this can happen to the ecu.
