johnnyballs180 »
https://forums.nicoclub.com/johnnyballs180-u106780.html
Tue Dec 02, 2008 1:54 pm
it took me a second, but if you're talking about replacing the slave cylinder, then you're probably referring to this:
i found this on one of the forums.. i forget which. i think it was NICO..
look inside the transmission, just right of where the dust cover inserts.
the clutch fork (clutch fork, right?) is held onto that pivot by the retainer spring. you can see that the clutch slave cylinder actually pushes on the fork, and the whole thing pivots on the.. pivot (lol), and pushes the throw out bearing.
i replaced my clutch with a twin plate and contemplated changing the pivot ball too, but my original was fine, so i chanced it and no problems thus far.
