WDRacing »
https://forums.nicoclub.com/wdracing-u3125.html
Fri Oct 07, 2005 12:18 pm
If you have no idea what you're doing. The best thing to do is read and ask questions.
Your plan is actually quite smart. Building the spare motor over time allows you to do everything right the first time without taking short cuts.
What you'll want is the S13 turbo kit. Since the post 91 KA24DE's are all the same as far as the block and head go, aside from cams that is, but thats a whole nother topic entirely.
The chassis is the deciding factor for the turbo kit since you have to deal with what manifolds will work and what intercooler plumbing will line up. The S14 and S13 kits very slightly, but it's enough to make you have to cut and weld a few choice pieces.
Check out our KAT sponsor IAP, Import Auto Performance. If you need help just give them a call. Good guys...
