Primered the 240
Twinchy
Car: Peg leggin 240sx
where can i get them at. and is it a a hard job?
IveBeenBad
Car: 1990 Nissan 240SX Fastback STOCK BIOTCH
Twinchy wrote:where can i get them at. and is it a a hard job?
you can get washers at any hardware store, and it is simple as pie...
remove hinge bolts, stack washers, replace hinge bolts...
IveBeenBad
here is a how to for it
http://www.nissaninfiniticlub....shers
Twinchy
kool let me check it out
Twinchy
so do you think its better to go with small washers or larger ones
IveBeenBad
Twinchy wrote:so do you think its better to go with small washers or larger ones
are we talking thickness or diameter?
Twinchy
ummmmm......... both
cdiesel12
looks good but damn parked close to teh curb there lol
book-ends
Car: ???? Nissan 240SX coupe S13
Hello,
I'll say it: I copied SCC and painted my coupe flat black. However, I don't care for the look because no matter what, if you use the rattle can, it's going to look uneven. The new plan is to rent REAL auto paint equipment and spray the car with a pressurized gun. I figure four coats of flat black primer, four coats of flat black base and four coats of doped clear coat should make it look nice.
Has anyone else noticed how quickly small chips start to rust on primered cars? I have to completely re-sand before I do the paint again!!!
SloS13
Twinchy wrote: can you give me some pointers on what do i need and how did you do it? it would help out alot thanks.
If you have any rust spots anywhere, you're gonna want to sand them down and fill in with some bondo. Any deep scratches you have, you will want to sand (180-220 grit) and fill in with bondo putty. What I did was just scruff up the clear coat with 220 grit, mask off everything I didnt want painted with a roll of craft paper from Office Depot and some auto-grade masking tape. The color I went with was Dupli-Color Hot Rod Black Primer. Duplicolor was the most expensive that Advance Auto carrried, so I figured it was a good bet. I think the whole car took about 10-15 cans. The hood is a pain in the buttox because its a horizontal surface and rattle cans dont like anything but vertical surfaces, so unless you remove the hood and paint it separatly, I have no idea how to make it look nice. Lemme know if you gots any more questions
DGA
Car: Cars
SCC describes that you would have to spray in random patters so that it hides that it is uneven. They also applied many coats. I will dig up the issue and copy down the instructions.
driftnS13 240sx
Car: racing
ya i primed my 240 jus like that it came out pretty good not sure what color im paintin it yet though does neone know the paint code for those drift show 240's (its almost a burnt orange color or something)?
IveBeenBad
driftnS13 240sx wrote:ya i primed my 240 jus like that it came out pretty good not sure what color im paintin it yet though does neone know the paint code for those drift show 240's (its almost a burnt orange color or something)?
The signal twin cars? Its Kandy Orange by House of Color I'm pretty sure
driftnS13 240sx
Car: racing
ok kewl thas wat i was thinkinthnx IveBeenBad
marshun
what happened to my sig
