znelson »
https://forums.nicoclub.com/znelson-u36902.html
Fri Jun 09, 2006 4:56 am
Depends on how much you are looking to boost. <300hp (I say 300 to be extra safe, I know stock internals can handle around and above 350hp.) I did a basic rebuild, cost me about $400 all together including timing, gaskets, hg, etc.. for boost id reccomend a metal HG (cometic is good) arp head studs and main studs plus the basic gaskets, pistons rings, and of course, cleavite bearings. Should run you around $700ish with that build. There isnt a need for pistons or rods unless you either have a lot of money to spend or want a mean boosting motor. If you are planning on changing them in the future, however, now is the time since theres no reason to tear the motor down twice. Hope the advice helps.
