Price of Ignition coil???
Bman0001
Does anyone have a price of an ignition coil? I was quoated almost 400.00 for the part through the local stealer. I sent the car in for a oil change and a tune-up. The car is a 97 q45.
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
About $175 from Joe.
Bman0001
Whats the websight? Also whats the best plugs and wires I can get?
paranoidjack
Car: 2012 Infiniti M56 S
2003 Infiniti M45
2001 Infiniti QX4
2000 Infiniti Q45
1998 Nissan Pathfinder
1996 Infiniti J30
Bman0001 wrote:Whats the websight? Also whats the best plugs and wires I can get?
www.everythinginfiniti.com
just call and speak to Joe, tell him you're from NICO, and he'll get you what you need cheaper than anywhere else.
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
The website is http://www.infinitipartsusa.com or the other.
Wires?
supermoose
Car: 1995 WRX STi-RA V3+2 V-Limited. 92 Q45 thats getting setup for wangan
the later black plastic ignitor is same oem part as SR20 and JDM Ej20g, 1993-1995 jdm wrx. if you need an ignitor i have one I guarentee 100% is good - i can take a video of it running a car, with both plug ends from ej20 wrx. the eariler is the metal one with heatsinks, and that one is same as early sr20. you can switch back and forth
$85 shipped.
see if its a black plastic chip with a 5 wire one side and 4 wire the other side. if so, i have the direct plug and play for you. you should have one ignitor per head
VH45 should have no plug wires. the system should be a coil on plug, so it goes;ECU signal -> ignitor ->coilpack spark to spark plug direct.
Modified by supermoose at 10:04 AM 6/26/2007
