cadet »
https://forums.nicoclub.com/cadet-u26312.html
Fri Apr 01, 2005 6:57 am
I can get harnesses wired by a guy here in houston for $75 each, and do an engine swap over a weekend, I guess it depends.. if it was someone I knew I'd probably do it for a couple hundred (that be 100 dollars labor a day) but for someone that just wanted me to do it for them, probably 3 or 400....its such a simple swap that I can't see charging much more than that. If a shop quoted me $1000 bucks I'd laugh and walk out, but I know just how little work is involved...
oh and I want to add an edit here, it would depend on what they want you to do as well.. obviously if "swapping" involved installing a new o2 housing, downpipe, catback, instrument cluster, relocating the power steering resevoir (for sohc) or other work, it should probably cost more...
