Price for clutch install
Nissan 350z / Nissan 370z general community discussion forum
Shiryuu
i need to replace the clutch on my wife's 06 350Z. if i bring in my own clutch to the shop, what is the average going rate for a clutch install on the 350Z's?
Tennz
Car: 05 350zr
Shiryuu wrote:i need to replace the clutch on my wife's 06 350Z. if i bring in my own clutch to the shop, what is the average going rate for a clutch install on the 350Z's?
Labor: $278 - $354
http://repairpal.com/estimator/
albert_ey
Car: 2007 Nissan 350Z
Sounds about right.
FYI- DIY!!
redsx13
Car: 93 240sx 03 350z
Shiryuu, do you plan on replacing the flywheel as well? i was told that when you replace a clutch on a z, you must replace the flywheel as well. (reason being, the flywheel is so close to minimum thickness, that it can not be machined down when you replace your clutch (which btw you have to do unless you want your clutch to slip like a mother******)
HPz350z
what kind of clutch are you going with?oem?
Return to “350z / 370z Discussion”
