nissangirl74 »
https://forums.nicoclub.com/nissangirl74-u124660.html
Thu Jul 24, 2014 2:02 pm
If / when you go look at it, before you start it, take a look at the fluids. The coolant should not be brown, the oil should not be milky, take a look at the radiator overflow reservoir for any suspicious goo. Battery terminals shouldn't be corroded, cables should not be frayed, belts should not be dry-rotted. Find out how long it has been since the truck was driven. If it has been a REALLY long time, if there's any fuel in it, it's probably no good - or not very good - and probably shouldn't be slung up into the fuel system. It's not good for any vehicle to just sit and not be driven. Seals wear out and crack, leaks form. Check for leaks on the ground under the truck.
