silkysmoothyjud wrote:..........but I think Ill I need is that under the seat computer box to finish the job. Currently, my seat computer does not have plug ins for the heated seat cushions. Does your pute have those specific plug ins?
I was able to unbolt my driver's seat today and do some checking for you. The P/N of the seat controller installed with the heated seats is 28565-76U01. The P/N of the seat controller removed with my old seats (a base model) is 28565-67U00. There is only one electrical harness feeding the entire seat (large white plug, lower center) and it originates from the center console.
You can compare your seat controller and harnesses to the the pic but I'm going to go out on a limb and say if you're switching to heated seats you need the seat cushions with built in coils, the seat controller, and the entire electrical harness from under the seat. You should be able to install these parts onto your existing seat frame and make it work.
In the pic I believe the seat heater plug is the brown connector in the lower left. That's the only 2 wire connection I could find but there should be a second one somewhere. If my theory holds true you won't have this plug under your base Q seat.
