previous problem found out
quiksilvia
Car: 95 s14 se
some may remember that i had a boost prob and a tap noise a couple weeks back, it turns out that my spark plug for the #3 cyolinder keeps working its way out, and i tourqued it pretty good. anyone had this problem? i know i can either get amother head or redo the threads, any other options?
MojoMan
Car: working on cars and women
Well......are the threads stripped out? dont muscle tork the hell outta it. If the threads aren't stripped than thats good. But if they aren't stripped and the plug keeps coming out then something wierd is def wrong. I wouldnt recommend using lock tight but I would try something.
SpeedRacer1
Car: 1990 240SX, G35
Its time for you to get a torque wrench and quit guessing.
BuudWeizErr
What are the torque specs for the spark plugs?
VitaminT
Car: 93 240sx SE
BuudWeizErr wrote:What are the torque specs for the spark plugs?
14.75122 ft/lbs to 21.38927 ft/lbs
I find it hard to torque spark plugs due to the low torque value and I only have a 1/2" drive wrench. It would probably be better to do it with a small wrench.
quiksilvia
Car: 95 s14 se
well thanks for restating what i said mojo, but yea the threads are bad, i called the shop that i got the clip from and they said that they would give me a new head to put on, so guess what i get to do next week? buy a new head gasket and other ish and replace the head, i love cars. i talked to nistech and he thought i could retap the hole and put new threads in bla bla bla, but if i can get a new head-thats the way to go for longevity of the motor. well...problem solved i guess :(
NISTECH
you could try some good loctite to get you by till monday when you get the head. that was mentioned by one of the other guys. after you called the second time i told them about your delima.
quiksilvia
Car: 95 s14 se
thats whta my buddy said, its getting worse is the problem, so ill try that stuff tomorrow, i have a friends car for the next couple days so im not too worried, thanks again scott
NISTECH
no prob brandon
quiksilvia
Car: 95 s14 se
i can get the parts for about 400$ and do it myself, or pay to have it done and be out of $1000, i hope this isnt too hard...im poor like whoa
Machine
if the head is free what costs $400? besides like 100 for a head gasket
quiksilvia
Car: 95 s14 se
im getting a metal apexi hg, and arp head studs, the other gaskets, and coolant and oil
