preturbo setup
novaspirit
Car: nissian 240sx coupe
had a few questions about preturbo stages. i'm trying to install stuff day by day without having to put the car off the road... just cirious if i was to install my sfac2 while it's still bone stock.. what setting should i use? 0 all the way through?
240sxvaj
Car: 1991 240sx fastback KA-T- SOLD!
1994 MKIV TT-Daily/Track
Yes just set everything to zero for fuel correction. you should be fine
novaspirit
thanks for the reply, what if i have a intake and 2'5 inch exhaust? still 0 ria?
240sxvaj
you can put exhaust and intake on a stock car and dont have to tune anything.
unless if you are installing the turbo then you would need to get a few things to make it run right. because you are messing with the airfuel ratio.
Miller White
Car: 1989 240sx
i put mine on and i have header exhaust and intake and its all set to zero
