Shocker »
https://forums.nicoclub.com/shocker-u18595.html
Wed Aug 29, 2007 5:38 pm
Well, thankfully to the person who posted the RB cam shaft issue regarding his CAS sensor, and aftermarket exhaust cam shaft not having the right key... I decided to look at mine.. I finally got my valve and head back and reinstalled, all do to the many problems I have had this summer.....
Anyways, I decided to inspect my exhaust cam shaft gear, before placing it back onto my head.. Well I compared the key on my HKS exhaust cam to that of my CAS. My cas is the star and half moon inside shape. My HKS cam shaft is just a slot.... Which I presume is a s2 cam shaft, and not a s1 exhaust cam shaft....
So I insert the first of 3 CAS I have aquired since I figured my CAS was bad from the crazy RPM signals my ECU was getting causing my motor serious Catastrphopy's.... and my lost of time and money. Anyway, I found I could insert my CAS any way I wanted, didnt matter how I turned it unlike the stock camshaft. So I spun the head of the CAS and the dowel that goes into the HKS cam stayed in the same spot.. ok cool.
Next I removed the O ring around my dowel on my CAS. Inserted it and turned the head of the CAS.. and what do you know... the dowel turns as well.
Turns out the only reason it seems my motor ever got a signal was because of my O ring causing enough friction to hold onto the exhaust cam shaft............. Im assuming as it started to get warm, and the engine was making full boost on the dyno.. IE 5000-5500 rpms, where the damn thing blew up. It was just to much force causing the CAS dowel to slip and cause my crazy RPM signal and thus predetonation....
heres pics, check it out....CAS dowelStock exhaust cam shaftHKS cam shaft
and yes I ordered a S1 256 8.8 lift intake and exhaust camshaft.....
