DAEDALUS »
https://forums.nicoclub.com/daedalus-u128.html
Sun Mar 20, 2005 10:41 am
Sure cats take time to heat up but that's not related to the engine running rough. The "smoke" you're seeing after a couple minutes of running the engine is probably just steam from condensed water in the exhaust. Moisture can't condense in a hot pipe.Perhaps the cold weather is affecting injector seals? When the engine is running rough get under the hood and start wiggling harness connectors--MAF, CAS, injectors you can reach, etc. Again, contact resistance might be the problem. Unfortunate that these older cars are reduced to such barbaric methods, but they are quick and cheap.
