The seats are not the same, but they are removed in the same way. Verts have unique back seats.Loki wrote:Threadjack time! The actual seat of the backseat of the vert is the same as the one in hatches and coupes, right? Two plastic pull-tabs and the thing just lifts right out?
Should be a little smaller/narrower and the top of the back seat doesn't henge like the coupe/hatch does, just bolts in at bottom and has slide holders at top.Loki wrote:How exactly are they not the same?
Top mechanism takes some space in quarter panel area, so seat is narrower than coupe's and hatch's.Loki wrote:How exactly are they not the same?
Yes as long as the other repair isn't a total hack job which will be difficult to undo.llarashill wrote:would the proper way to fix this is to cut out a same section from a differnt S13, then cut out the sheet metal area and then replace it with the section from the other S13??
