I cant deal with that clunky noise in the corners on that vid....otherwise I like it.sjbsuperman1425 wrote:http://www.youtube.com/watch?v=NHKAjZlpUwI
this is my fav. i think its about 330whp right?
Do you have the 4.36 OEM silvia rear end?Hillkill wrote:But how many people have that much power??? I'm putting up a respectable 280hp out of mine but I still don't get as much smoke when i drive my buddies rb25 s13... I'm just over the lack of smoke these engines put out. Don't get me wrong I love it to death but I might be selling mine soon.
I wouldnt go with 3.8 gearing unless you were high HP KA-T and you wanted to use first gear from a stoplight. If you want more tire smoke you will need more torque...and the 4.3 gearing the CA18DET came with in S13 silvias delivers more torque in lower gears than the 4.09 or 3.96 (USDM S-chassis or J30 respectively). Trust me...the lower the gearing...the more it's just a highway cruiser...not a drifter.Hillkill wrote:Had a 4.11 in the s12 the ca18det was in. I ended putting that car into the wall @ redbull Drifting in Long Beach. So Now it's sitting in a s13 with v-mount thats getting finished up right now. But this time I'll be using the stock ca18det transmission in the s13 instead of the stock ca18et transmission i was using in the s12. I'm also gonna see how the stock 3.8 diff will work out when i'm done. And hopefully the higher wheel speeds from the longer gearing will get me more smoke too. But if I get too fustrated I may just go to the dark side and add 2 more cylinders.
