I forgot to add that I have been using Costco fuel for a few months because of the price and location. But recently I switched to Shell. I used Redline S1 in a half a tank of fuel which made little if any difference. The car rarely sees anything above 2K RPM's and I drive at 55 MPH no more than that because that would bring the RPM's a little higher than 2K RPM's.
I have not tested the fuel injectors after a ten minute hot soak but I will do that ASAP. But the bad injector like shake happened again this morning after a rain storm. Come to think of it, it mostly happens when the car sits over night and moisture builds up on it.
I have grounded the fuel pump and taken the car for a drive and I noticed no difference whats so ever. So the fuel pressure may not be a issue at all.
I plan on doing a fuel pressure leak down test and seeing if possibly a o-ring let go or something. But that is just another test that will come back normal I bet. At this point I know its a fuel injector I am just saddened that it can be because they were all replaced a few years ago. I guess I will be doing the plenum next summer.
If I could find someone I could trust locally I would hand them the keys and tell them to fix it and not come back till they can balance a quarter one the plenum!
