Also, your turbo oil drain will be pressurized and wont allow good flow of the oil back into the pan. You will most likely end up with an oil consumption problem in addition to being mistaken as a misquito control truck.:: orion :: wrote:Pressurized line going to the valve cover breather is bad, bad, bad...
It forces oil out the front and main seals, etc...
Use a breather, or hook it up before the compressor if you must.
- Brian
