Pressure switch instramentation
Stoneage_Turbo
Car: 1994 Caddy Deville 4.9
Just about anything
not sure where to post this but i thought some of the turbo kids mike like this one , been doing some research and posted this in G20.net too
and pardon me if i sound like a nerd here , i rarely have a decent thought , oh and painkillers rule , the left hand works again!!:arcadefre
finnaly figured out a way to get around haveing a boost gauge the car , found adjustable pressure switches called "Hobbs pressure switches" figured i could run a few these to various places like the intake manifold for boost then to a LED light in a discreet place around the gauges , since im only concerned about boost makeing it to 7psi and if its getting over 8 psi i figure i dont need the extra clutter of a gauge hanging out in there 2 of these switches with a blue "ok" light and a red "overboost" light should do the trick .
been researching it all night so far ,along with a way to stuff a small intercooler in the stock airbox with a small fan . then placeing the airfilter someplace cooler , but i dont think the intercooler will get enough air in that box so im back to the drawing board on a intercooler , really dont want one in front of the raditator. but i digress , heres what i have found on the switches :
this is a part that goes in a turbo diesel pickup that has the hobbs switch in it :http://www.atsturbo.com/produc...od=20
one at the hobbs corporation :http://www.thomasregister.com/...5.htm
this one is at crane cams P/N:9000-0110 , not sure about it tho see "Driver-Adjustable Ignition Timing Retard Control" 4th paragraph :
http://www.cranecams.com/import/controls.htm
anyone got any thoughts on this ?and you thought my YUGO fettish was bad :Werd
