slow40 »
https://forums.nicoclub.com/slow40-u57194.html
Wed Feb 03, 2010 7:44 pm
ok, the fork is gonna have a little room to move before you get your slave cylinder mounted back on and get the line bled out. you are more than likely just sliding the throw out bearing up and down the input shaft. Even in a completely worn out clutch, it would be very difficult for you to release the clutch plate with just your hand. The slave cylinder puts out alot of pressure on the fork, well, alot more than your hand can.
