Pressure in the crankcase?? Common Problem?
masitaly17
Car: 2003 G35
Hello,
I am doing some research for a buddy of mine with a 2003 G35. He had me look at his car for a "noise" towards the left front of the car. I thought it was going to be a belt but ended up being more of a pressure noise than mechanical.
I took the dipstick out and sure enough the crankcase had pressure in it (pressure relief noise when removing dipstick). He picked up a PCV valve and it still has the same noise. A buddy said he vented one of the hoses in the PCV circuit to atmosphere and it went away.
I figured this is likely a common problem with these engines and you guys could share your thoughts. I did a search but it did not yield much.
I am an engine guy but do not know anything about this specific engine.
Your help is apprcieated in advance
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
PCV valve?
Q45tech
Venting the designed in crankcase pressure throws the MAF voltages for a loop.
The question is how much pressure and does it exceed oem design? Poor ring sealing [bad rings] cause excess pressure.
Normally as compression pressure drops crankcase pressure increases.
Installing new fresh PCV is a good first start.
Now measure each cylinders compression pressure and compare to parameters in FSM.
