4xq »
https://forums.nicoclub.com/4xq-u207684.html
Mon Jul 27, 2015 9:36 pm
Yep, I would definitely pull the cat and check it since you are in there. Definitely seems odd.
As far as the MAF, page EC-182 of the FSM has wire colors and voltages. There is a wiring diagram on EC-185. 5 volts is the voltage suppied to the MAF on pink/black. Other wires are as noted in the table. Looks like you need to check Orange.
It sounds like your cooling system is working well other than the pressure issue. Since you are not losing coolant, your head gaskets, hoses, etc. are fine. I think a new radiator cap may fix you up there.
