Prerunner suspension
jmanto17x
Car: 1996 Nissan ex 4x4
I got a 1996 Nissan 4x4 pickup, im wondering if the make a Prerunner suspension kit, or any off-road kit like that, any info would help thanks
RT22
Car: 1991 nissan hardbody
I think rancho makes some stuff for the nissan 4x4's
Desert Rat
Car: 2014 370Z M6 Base Coupe
2017 Frontier 4.0
2007 Dodge Ram 2500 Cummins Quad Cab 4x4
1977 F150 4x4 Shorty BUILT
2008 Boulevard C90T
Previous owner of a bunch of Nissans
prerunner stuff is typically for 2wds. you might look into Total Chaos. They may make longer halfshafts and a longer arm front suspension....
Rancho just offers the standard 2.5-3" lift like everyone else
seang
Car: Ford Fiesta ST
That Total Chaos long arm stuff sounds great, but I have thrashed the stock IFS, and it can eat up some whoopty-doos pretty good. I'm not saying it is the best, but if you got good shocks and other parts it can be pushed kind of hard.
I haven't broken anything on mine so far (partly owing to my decent driving skills), and it took the bumps better than I thought it would, but the stock shocks are now hit, and I want some new monotubes post-haste.
If I ever get the chance to retire my truck to a weekend toy, I will be thrashing it again. I can't afford to break it right now.
4lo feels like a rally car cause you gotta shift the gears so fast, 5th only hits 47mph with 31x10.5's, but that also is hard the transmission, and I would expect it to blow up smashing through the gears on the regular (the countershaft bearing is known to fail, causing catasrophic damage to the case). I think I might have taken a few hundred miles off of mine, so I might overhaul it someday before anything really bad happens, it is known to happen on these.
OP, have you reached the limits of the stock IFS?
Oh yeah, one more thing; the stock bump stops are bolted on, but the rubber is only bonded to the plate with glue or something, so thrashing around and "bumping" them will eventually seperate them, especially if they are rusty, and they will fall off. I have thru-bolts on mine so they would have to disintigrate to fall off.
Modified by seang at 4:08 PM 2/9/2010
jmanto17x
yeah, i have drivin my truck to pretty hard and the stock does do really good, just like the looks and stance of a prerunner and thought it would be a little easier on my truck.
I was thinking, would a 2wd kit work and just get or extend the cv shafts, or am i forgetting some other stuff?
seang
Car: Ford Fiesta ST
I went to the Total Chaos webisite and I didn't see anything for 4wd Nissan's, only 2wd. There was something for 4wd Toyota's. Do they have multiple websites?
Anyways, the 2wd kit says that the 3 inch extension gives 11 inches of travel, which is double stock, that sounds pretty cool.
I don't know if the 2wd kit would work with a 4wd, Desert Rat might know.
Rev_D21
1991 D21 Reg 2WD Auto
1995 D21 Reg 2WD 5Spd
1996 D21 Reg 4WD 5Spd
2012 Versa 1.6S 5-Speed
Check out Fabtech, they make susp parts for 2 and 4wd trucks.
darinz
Car: Nissan Patrol
There's plenty of stuff out there for a D22 and the chassis are basically the same so something like this http://www.offroadwarehouse.co...37421 can probably be made to fit with minimal work.
