prepping for winter..
MaXimaSE
Car: 1998 Nissan Maxima SE
ok, winter is slowly approaching here in Pennsylvania. The first week I had the car I changed the Oil, Plugs, Filter, etc. and I attempted to do a flushing of the radiator, but low and behold I have a drain plug that is rounded off, their are no threads at all.. I really want to flush my radiator out but I guess Im pretty much SOL because of that damn drain plug huh??
When my girlfriend finds the digital camera, I will crawl under the car and take a picture of It.. its brutal.
any help would be appreciated..
00MaxSE
Car: 2000 Nissan Maxima SE 5MT
The drain plug is plastic right? Go buy a new one?
NutriaforBreakfast
Car: Nissan Maxima 1995 VQDE engine
Get your screwdriver to take out the SCREWor wrap Nutria fur around radiator
MaXimaSE
yeah the drain plug is plastic, but It is impossible to get out of the bottom of the radiator. There are no threads on the plug at all, It just looks like a shredded peice of plastic where the threads would normally be..
Nutria Fur?
NutriaforBreakfast
Drill it out or use Nutria tooth to pull it out
maxhopper
Car: 02 Maxima SE 6spd
If you're just looking to clean the radiator itself, you can always remove the upper and lower hoses and flush it with water.
If you want to flush the entire system, some shops have a machine the hooks up in line with the upper radiator hose and replaces all the coolant in the system.
