DeXteR »
https://forums.nicoclub.com/dexter-u32945.html
Thu Feb 22, 2007 3:21 am
personally, i think if you picked that vert up for $400, you should just count that your new daily driver and try to find another hatchback or a coupe.
there is a substantial amount of extra weight (as has all ready been stated) from strengthening the chassis. not only that, but are you even allowed to run 10's in a convertible?
however, if you're dead set on drage racing your vert, it's your call and i'm no one to tell you otherwise. you bought it, you might as well love it regardless of what you decide to do with it.
anyways, normal gutting like you'd do with any car. there's a lot of extra metal behind the driver seat that you could probably just cut right out. also, yes, the convertible top can be operated manually if you remove all the lines, rams, pumps, etc. for the top. skin the trunk and hood. remove the bumpers. remove hvac compressors, condensors, ducting, and related items. remove all unneccessary wiring. a guy i know who was building a drift car removed about 25-30 pounds of wire and loom. make sure the doors you get have manual locks and windows, then you can get rid of all those related parts too - wires, switches, relays, etc. if you're not streeting the car, remove the headlight assemblies and just weld the light covers to your hood and fill as necessary. tubular subframes would save you a ton of weight. maybe even consider revising the top. maybe you could make your own frame for it so it comes off and on like a hard top. that way you could remove a lot of the moving parts associated with the top. dont' know if that would work, but it's something i thought of.
all right, that might be a bit of a ramble, but i was just typing things as i thought of them. hope that helps.
oh yeah, if you want, i'll come pick that car up from you for $600 and you can use that to buy a new coupe/hatch
