hysteria »
https://forums.nicoclub.com/hysteria-u25294.html
Wed Apr 27, 2005 5:27 pm
ivan made just over 400 hp on a stock never opened up engine... no new cams, no port polish, no nothing... just a good fuel and turbo setup...
the key to power is fuel management... if you have a good fuel setup you''ll make 300 hp easy on the stock engine and everything will just be a bolt on... you won't have to do anything to the head, block or anything. learn more about fuel magement- the different options (for example piggyback, stock ecu rom tuning, daughterboard ecu upgrades, stand alone systems, fmu's, and many others), and what they cost, what they are good for, what one is right for you, etc... just search the forums there is tons of info about all of this. good luck.
