Preparing to change 98' timimg belt.
plowjockey
Car: 1998 Pathfinder XE
My 98" Pathfinder has over 135K miles so it's way past time.
I have the Haynes manual, but could benefit from some other resources.
Where is the best place to purchase a quality replacement? Anything else to check or replace while I'm in there? I also going to replace the fan, etc. belts.
Any input is appreciated.
Marty
ganesh21
Car: '12 Honda Pilot
if you are going to change the timing belt. Change the water pump, change all 3 belt and check the fan clutck. I am not sure if the 98 pathfinder have a fan clutch.
Chuck Tribolet
Car: '01 Nissan Pathfinder
'87 Chevy Corvette
'01 Toyota Camry daily driver
'98 Boston Whaler Montauk
Do have the factory service manual.
Follow the parts about what to align with what RELIGIOUSLY, and double andtriple check that it didn't move.
Make sure you have all the gaskets and sealants you need before you start.
