Preparing Maf for blow thru
240slidekat
Car: 240sx, 280z, gsxr1000, m3
what do you guys do to prepare the maf for a blow thru set up. i have read that some maf tend to leak under boost. just wondering what do you guys use to seal it? im using a q45 maf.
Ni2s4s0aSnX
Car: Nissan 240sx 2.4L 12Valve
Leak? You mean air, is it that big of a deal?
240slidekat
well im goin to be boosting pretty high i just want to make sure everything will be ok.
jt15833
Car: 95' 240SX
radiator hose and t-bolt clamps will do the best job of sealing, however the life of the maf will be reduced if its seeing boost
zukitek
Car: 95 240SX-SE
I have supercharged and turbocharged many cars and everytime I tried to blow through, it had many drawbacks .It should be on the intake side of the turbo not on the output side . This is just my personal experience
Ricky
Globalsilence
I just got my car running; it’s a fully built KA-T. I decided to go blow through and I love it. On the way to the exhaust shop I blew an IC pipe, the car still ran. I blew a few other pipes on the way home because the couplers I used have wire on the inside so they don’t clamp at all. Anyways the car still made it without a problem Try that with a draw through setup. On the MAF itself I have a 3” in to 2.5 in reducer, my car hasn’t seen more than 10 psi but it seems to be holding fine.
