Correct - both sentences.06M35Sport wrote:Sounds like the m45 really needs to use the higher octane gas and the m35 could possibly use the middle grade. I guess it does say its reccomended but not required.
Good Stuff™!06M35Sport wrote:I have been using the high octane gas and like I said the difference in cost is not that much, but I was just curious if those extra bucks I have been spending were even making a difference. I dont have a problem with the extra cost and from these posts I will continue to use the premium gas. I just dont want to damage anything in the engine. Those extra dollars are worth keeping the engine running great. I knew this going into the purchase and dont have a problem with it. I agree, if I cant afford those extra dollars at the pump a year I dont need to be driving this car. With that said, I appreciate the responses and this answers my question. I will continue to use premium gas.
I think I've noticed the same in my m35x but I'm wondering if it's just a placebo effect.bfournier wrote:I have a 2006 m35x and just recently started putting 91 or 93 regularly and have noticed a difference...specifically acceleration and seems to more responsive
Yes, they are. If a car does not REQUIRES premium, it will not hurt the car running on 87, but you will feel a difference in performance and at the same time a gain, yes, gain in MPG. since premium gas has less energy than regular, it just has a higher ignition point (for the high compression ratio).Zamba wrote:I think I've noticed the same in my m35x but I'm wondering if it's just a placebo effect.
Wise man are you. The '06 M35x does just fine on regular-unless of course you drive near the red line all the time.Zamba wrote:I think I've noticed the same in my m35x but I'm wondering if it's just a placebo effect.
Do you have timeslips showing the difference?EniGmA1987 wrote:So the slower 0-60 and especially 0-100 times are just in my head? Thats good to know.
Actually, the M DOES know the difference, and that's what's important. VQ35 will run on anything 87 to 93 (maybe even 85, I've never tried it). But there IS a difference. With 91, the car can operate with optimal timing advance. With 87 it cannot. It makes less power and is slightly less efficient. That's why the engine has knock sensors: to compensate for lower octane fuels. Key word is compensate. It works and is not harmful at all, but is less than ideal. Most modern engines push the limit pretty hard with high compression, so they're very susceptible to knock from low octane fuels. To avoid knock, timing must be retarded and power is lost.antzrus wrote:Your precious M35x doesn't know the difference between 87 and 91. But your brain does...
This issue of 87 vs 91 reminds me of the issue of oil changes, 3000 vs 15000. In all my 46 years of legally putting these rolling objects down the road and when I was saving my pennies putting just about any old viscous oily substance, the cheapest the better and gawd knows how long before changing, I never, ever had a problem w/an engine caused by the oil; even after finding that there was hardly any oil on the dipstick!!!Poyzinous wrote:There is a lot of misleading info out there. The VQ was designed and built upon 91 octane. Use 87, you WILL experience engine knock and a loss of power. Take your car to a dyno on your 2nd tank of regular. Take it back on a 2nd tank of premium. If the results are unchanged, I'll double the money you spent on the dynos. MPG honestly will only improve .5 to 1 mpg from 87 to 91, depending on driving habits. This is because the ecm will adapt to the crap you're feeding it. The M can run on regular, but there will be spark knock, there not be the 280 Hp you paid for, and you'll just look like a fake paying 50k for a premium vehicle and cheaping out on crap fuel. If you have an HD Television, do you have HD cable or HD tv programming? A HD/bluray dvd player? or do you have your HDTV connected to rabbit ears and wads of aluminum foil and a VHS player?
Modern engines have clearances and tolerances that are 2 to 5 times tighter than back in those days. Things are different. Thats why a Chevy 350 could only produce 220 net hp (claimed 300 then) with only 13mpg but a modern 350 can produce 50% more power with 50% better fuel consumption, not to mention it would take 7 of them to be as dirty emissions wise as an old 350. Either way, Being a tech I change my oil every 2500 to 3000 miles just because I can, and when you take a peek inside my engine with 55000 miles, I guaranfreakintee its cleaner than my neighbors 20000 mile accord with 5000 mile jiffy lube reprocessed oil change intervals. The motors on all infinitis can go 5000 miles between changes, but see the v6 only has 5 quarts to go through. The V8 5.7 quarts. 3750 miles is the recommended interval by infiniti because that is where you'll maintain optimum efficiency and life and reliability. You can go 5000 if you want to, but be sure to add a half quart to the motor, since it naturally eats about a tenth quart per 1000 miles, the V8 about 2 tenths. If the M's engine had a 9 quart capacity like some of the other luxury cars that have 7500 mile intervals, then you could brag about 7500 mile intervals between oil changes. Oh, and all i need is to stand within 10 feet of an M, drive it up a slight incline from a dead stop and I'll know if its using regular or premium. I've had to 'diagnose' many cars with a 'pinging' as the issue, only to advise the use of premium, and the customer never have the issue again. A member over at the G forum did a big research graph showing that the fuel economy improvement from premium over regular was worth the variance in cost of fuel when calculated to cents per mile, and you're better off using premium. Especially the more expensive gas gets, since the variance gap closes as the cost increases.antzrus wrote:This issue of 87 vs 91 reminds me of the issue of oil changes, 3000 vs 15000. In all my 46 years of legally putting these rolling objects down the road and when I was saving my pennies putting just about any old viscous oily substance, the cheapest the better and gawd knows how long before changing, I never, ever had a problem w/an engine caused by the oil; even after finding that there was hardly any oil on the dipstick!!!
But that's just it...that's what we're telling you. The issue is NOT perception, it's mechanical fact. Just because you can't tell the difference doesn't mean there isn't one. For those looking for a noticable difference, sure, your point may be valid. But there is fact, undeniable fact, science, go ask the engineer who built the motor, that lower octane fuel reduces performance and economy because it forces the engine to operate outside optimal parameters. You can go on about advertising and placebos all you want, but either you don't understand what you're talking about or you're ignoring basic physics. Advertising doesn't change compression or gasoline's knock-resistance.antzrus wrote:Come on folks, the degree of pinging and the degree of mileage loss and the degree of horsepower loss @ normal, sane RPMs is not within human sensory perceivable difference as already noted above. You need an especially adept mechanical device to note the difference, not the human central nervous system.
The true difference noted by humanity w/out all these inhumanly precise instruments measuring this and that is as William James in 1890 so aptly stated: "Whilst part of what we perceive comes thru our senses from the object before us, another part (and it may be the larger) always comes out of our own mind."
