Premium Gas on the vk56vd Titans
Covering the 2003-2015 first-gen and 2016+ Titan and Titan XD lineup
TeKNiX
Car: 2011 Infiniti M56x
The vk56vd were first used on m56(q70) and qx56(qx80) 2010 and onward with prem gas and 420hp 417+ torque. can take regular gas but runs poorly.
Now it is being use on current Armada, Titan and xd and called endurance engine and uses regular gas.
Any advantages using prem gas on the endruance engine?
RicerX
Car: '20 Titan Pro4X
I don't personally see it being an issue - the owner's manual says regular 87 octane is the recommended fuel.
Where I have noticed a difference is crappy gas. I stick with Shell, Costco, and Kroger fuel and my 2017 runs great on it with roughly 17mpg on my commute.
Your power ratings listed on the first two were tunes that required premium fuel. The current version of the VK56VD in the Titan is 390hp/394tq in the half ton gasser (I believe to also be the case for the Armada). I believe those numbers are up a tad with the XD.
FlawleZ
Car: 1992 Nissan 300ZX TT
1987 Nissan 300ZX Turbo
2017 Nissan Titan SV 4x4
They are detuned a bit in the Titan to accommodate the 87 octane fuel. No advantage unless you have the truck tuned with uprev or a timing advance.
Return to “Nissan Titan Forum”
