The FX will adjust to whatever fuel grade you choose. If you use a mid or lower grade the FX will run fine, but performance will suffer. The computer & sensors will protect the engine at the expense of maximum performance. If you are simply going to keep up with traffic & use your FX35 in the "Commuter Mode" mid grade fuel will be fine. If you intend to make regular use of your FX35's High Performance side use 92 octane or higher fuel & enjoy.Salsa wrote:Why do they recommend premium? That's all I've been using so I don't have anything to compare it against.
As i stated previously the FX35 will run "Fine" on whatever grade fuel you put in it, the Fuel Management software in the ECU will retard timing to eliminate engine knock & damage. If you ever want to experience the full performance potential of your FX35, it'll require 92 octane or more.laudjo wrote:I have owned an FX for six months and have never put premium fuel in it.It runs fine without it and I have had no trouble.
