landtodd »
https://forums.nicoclub.com/landtodd-u258.html
Tue Dec 03, 2002 12:55 pm
True -- when you don't drive much, you tend to get away for longer periods or time (not more miles) with things like bald tires or abused engines. Here are some general thoughts about the gasoline question.
As the ignition timing backs off, as it must with regular, a greater percentage of the energy released by combustion is rejected as heat (unavailable for propulsion). The excess heat either goes out the exhaust or into the cooling system.
1. Even if your cooling system is 100%, you may be asking for trouble asking it to handle more heat, particularly when the warmer weather returns. Overheats are death to aluminum engines.
2. Passing significantly hotter exhaust by the exhaust valves shortens their life. Cold, hard economics dictates that an older Q usually isn't worth a valve job. Very, very sad, but often true. My assertion here is that running regular gas can endanger the car.
3. If your knock sensors aren't 100% efficient at preventing knock (impossible -- there has to be a knock before it can be detected), some damage will occur to the pistons. If an old Q isn't worth a valve job, it's certainly not worth a piston replacement. Granted, a hole in the piston isn't particularly likely around town, but every ping causes *some* damage.
In addition to making the cooling system's job easier, cooler weather means cooler intake air, and theoretically less chance of ping. Unfortunately, there's no free lunch, because fuels are formulated for the expected temperatures, so the cold air just balances things out. Other tradeoffs exist for other conditions, such as high altitude or oxygenated gas.
It's quite a balancing act. Any motor -- but particularly the Q's motor -- was designed around some assumptions. One of them is 92/93 octane, just like another is that the motor usually operate right-side-up. Screw with any of the engineers' assumptions, and bad things are much more likely to happen.
