lyon74 »
https://forums.nicoclub.com/lyon74-u141069.html
Sat Aug 22, 2009 2:28 am
You could go with middle grade as well. If you go with lower octane like regular you can cause the engine to "ping" Basically, you'll alter the timing slightly with a low grade fuel which will reduce the performance of the car. You could also build up carbon faster on the valves so I'd stick with atleast "plus" gasoline. Come on dude, would you put regular in your Vette?? I think not! Hey, make sure to send me pics of the wing if you get it!
